71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sloping Bar Joists?
Thu, May 7, 2009 at 8:44:35 AM | Sloping Bar Joists?
Studioe
Challenge: Generate a (nearly) flat roof structural system using bar joists with the "beam system" command.
 Problem: Bar joists are always shown horizontal. My roof has a slight pitch - is there a fuction to create a slope to these or designate elevations for each end?
Thanks,
e
Thu, May 7, 2009 at 8:57:07 AM | Sloping Bar Joists?
tim123
4 Stars: 19 Votes
You can rotate the beam system in elevation.
Thu, May 7, 2009 at 9:08:30 AM | Sloping Bar Joists?
Studioe
I get an error - can't rotate a pinned element
Thu, May 7, 2009 at 9:12:03 AM | Sloping Bar Joists?
I BELIEVE YOU ANSWERED YOUR OWN QUESTION ... UNPIN IT!
Thu, May 7, 2009 at 9:12:57 AM | Sloping Bar Joists?
tim123
4 Stars: 19 Votes
I think that you're trying to rotate a beam and not the beam system.  You need to select the beam system.
Thu, May 7, 2009 at 9:26:00 AM | Sloping Bar Joists?
Studioe
there is no function to unpin it, however, if I select the beam system like you mentioned (in plan view) and switch to section view, I can rotate the entire system. Thanks!
I just thought revit would have had more control for framing points, such as elevations from walls or beams.
Thu, May 7, 2009 at 9:36:45 AM | Sloping Bar Joists?
tim123
4 Stars: 19 Votes
You can use that functionality if you use the pick support function when you create the beam system.  The sketch lines will snap to supports at different elevations - see 2d and 3d beam systems.
Thu, May 7, 2009 at 9:41:08 AM | Sloping Bar Joists?
Studioe
That sounds great, but the bar joists are burried in slots in a bearing wall. Can Revit specify a bearing point within the core of a wall structure?
Adding roof bar joists on different hight brg. ends..
Fri, Oct 9, 2009 at 12:02:50 PM
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
Multi Sloping Beam System
Fri, Mar 16, 2012 at 9:54:44 AM
Manipulating Bar Joists
Fri, Feb 16, 2007 at 12:32:07 PM
sloping roof joists only displays on medium/fine
Tue, Mar 31, 2009 at 1:33:01 PM
Page generation time: 0.2898
