33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Can not tag beams
Thu, May 7, 2009 at 4:32:43 AM | Can not tag beams
cundall
im trying to tag all my columns and beams on a job i am working on and i get a message saying ''no tag is loaded for this type. would you like to load tag now'' but when i try to load the tag i cant seem to find a tag for it.
 i must of changed a tag family or something along them lines because i could tag them on the last job i was working on, its strange because it lets me tag foundation pads
 can  any1 help as i have a deadline to meet.
cheers
Fri, May 8, 2009 at 3:45:12 AM | Can not tag beams
gprakash
Assuming that you have modified your default tags, I have attached the tags for structural column and structural frame for your use. Hope this helps.
Fri, May 8, 2009 at 4:10:19 AM | Can not tag beams
4 Stars: 203 Votes
Cundall, you have that (if you don't delete) in your "Annotation" folder in your Metric/Imperial families...
Fri, May 8, 2009 at 6:31:19 AM | Can not tag beams
gprakash
You can also edit the tag family from your previous jobs and save it to the annotation family folder.
Fri, May 8, 2009 at 6:51:36 AM | Can not tag beams
cundall
cheers for your help, youve helped me alot
Tagging for floors between beams
Tue, Jan 31, 2012 at 5:23:10 PM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
length in beam tag
Sat, May 26, 2012 at 12:25:40 AM
Beam System Tags
Wed, Feb 27, 2013 at 12:55:27 AM
Beams at different elevations in one plan
Mon, Nov 21, 2011 at 11:51:21 AM
Page generation time: 0.6639
