71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> wall mounted toilet wall error
69 Posts No Rating |
hey folks: working in revit 2008 and have a wall mounted 2d toilet that i am trying to intall in a generic wall. the component will mount on other walls but not in the thickest wall. please see the attachement. is there a setting i need to check to make the wall able to accept wall mounted components? i searched through the history but could not find this problem
![4 Stars: 19 Votes](/images/stars_4.gif) |
Did you create the wall as a wall or generic model? If you need to create the wall rather than using the wall functions in Revit, it needs to be in the wall category.
it was the generic wall that is automatically loaded in revit, i did not create the wall.
Handrail - Wall mounted |
Fri, Apr 28, 2017 at 5:35:54 PM
Revit 2008 wall mounted family placement issue |
Mon, Jun 20, 2011 at 3:19:51 AM
handrail, wall mounted |
Fri, Feb 13, 2009 at 1:47:36 PM
Wall-mounted Railing |
Wed, Oct 14, 2009 at 12:20:47 PM
Wall Mounted Light Problems. . . |
Mon, Mar 23, 2009 at 4:23:36 PM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
