Forums >> Revit Building >> Technical Support >> vertical wall reveal troubles
8 Posts No Rating |
I am trying to use the Host Sweep command to create a 3/8" wide vertical wall reveal to represent a brick control joint and I am not having much success. I can get the reveal in the wall and I used revit help to create a new profile, but I'm not finding the way for it to actually let me put my new profile in the wall. Can someone help out or let me know if there is a better way? Thanks, Shannon
8 Posts No Rating |
Oh yeah, I'm using Revit Arch. 2009
Look at the properties of the sweep. You can set the profile in there, by default it's called 'default'.
8 Posts No Rating |
When I do that, the only options it gives me are a 1, 2 or 3 brick reveal. The trouble I'm having is creating a new profile and getting it so that it shows up as an option when I go to change the reveal properties.
Look in your H E L P - search sweep.... You guys need to start looking first - then come in here when you have real questions!
8 Posts No Rating |
8 Posts No Rating |
So i finally found the template for reveal profile family. I think I can get this to work now.
How do i make a foam wall with repeating vertical reveal |
Sat, Nov 18, 2017 at 10:50:49 PM
Wall reveal - Vertical |
Wed, Sep 2, 2009 at 10:55:00 AM
how to add a self made reveal to a wall while edit wall types? |
Sat, Feb 12, 2011 at 10:53:32 PM
Is it possible to put reveal on a wall that has been edited with a profile? |
Wed, Mar 2, 2016 at 6:54:34 AM
Vertical reveals to angle wall end |
Mon, May 11, 2009 at 11:36:01 AM
Members: | 2101578 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
