33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating Revision Clouds
Tue, May 5, 2009 at 3:00:04 PM | Creating Revision Clouds
haywood
4 Stars: 1 Votes
We have completed our first project in Revit and overall the program is great.  Now it's revision time and my current plan of attack is to make one segment and copy it a thousand times rotating here and there.  I know you can free hand it but the archs aren't consistent and it looks like garbage.  I can't believe I'm saying this, but I actually miss ACAD when it comes to creating rev clouds... draw out a polyline convert it to a rev cloud and done.  Other than that I take Revit any day Smile
 Does anyone have an eaisier way for completing this simple task?
 Thank you in advance for your time.
Using RAC 2010
Tue, May 5, 2009 at 3:44:42 PM | Creating Revision Clouds
wheelergc
Why not use the revision cloud under the drafting tab?
Tue, May 5, 2009 at 3:48:20 PM | Creating Revision Clouds
haywood
4 Stars: 1 Votes
That is what I am using.  But in order to get equal segments you have to make one segment and then copy it around the view which is very time consuming.
Using RAC 2010
Wed, May 6, 2009 at 8:05:45 AM | Creating Revision Clouds
I don't know anyone that wants equal segments - clouds are supposed to be random so that they stand out.  Clouds just mimic what we did with a pencil when we hand drafted and that was a free-hand element - no perfection here!
The cloud is a repeating element.   Just point and click as you go around in a clockwise direction and let them adjust to the spacing of your clicks.
Wed, May 6, 2009 at 10:01:21 AM | Creating Revision Clouds
haywood
4 Stars: 1 Votes
Well now you do.  If it's not a big deal, then why is it used in ADT?  There is a visual difference between the two (attached) and when they are on the same page next to each other it looks sloppy.  Just like everything else in this program it's about consistency.
Using RAC 2010
Wed, May 6, 2009 at 10:06:49 AM | Creating Revision Clouds
bert
At my office, we like to keep our revision clouds neat as well. When a lot things are going on on your sheet, you don't want clouds just jumping around everywhere. By using a thick line, they're easily noticeable.
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Thu, Nov 12, 2009 at 9:54:29 AM | Creating Revision Clouds
mnestor
Anyone have an answer to this? I am not concerned about the clouds looking exactly the same, but I do not like clicking the mouse so many time to create a cloud? In CAD you can set the length of you segment.
Thanks
Thu, Nov 12, 2009 at 1:47:53 PM | Creating Revision Clouds
TKennedy
4 Stars: 7 Votes
It doesn't help with the segment length (and with just a little care and practice you can get them close enough), but something I used to to do was trace where I wanted the cloud to be using detail lines, then snap to them with the cloud tool. The segments are all slightly different lengths, the the lines are straight and a bit neater looking.
Fri, Nov 13, 2009 at 6:29:51 AM | Creating Revision Clouds
I really think this is one of those "can't see the forest for the trees" issues.
You can edit - copy past - clouds just like other Revit elements.  Have a fe masters on hand....
Revision Clouds
Tue, Dec 18, 2007 at 10:52:45 AM
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:40 PM
shading revision clouds Revit 2017
Wed, Feb 28, 2018 at 2:56:29 PM
Revit clouds
Tue, Jul 29, 2014 at 10:43:13 AM
Revsions & Revision Clouds
Wed, Feb 20, 2013 at 1:32:14 PM
Page generation time: 0.6729
