69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> stacked wall line visable on the wrong side?
Tue, May 5, 2009 at 2:02:05 PM | stacked wall line visable on the wrong side?
barcardi
Currently i have a few stacked walls in elevation.  The elevation i am in shows one side of the stacked wall, this side of the wall is flush.  But i can see the stacked wall seperation from the opposite side, it shows up as a dashed line.  I have no idea how to hide it as any way i click on it selects the entire wall.
Attached is a blown up view, the highlights show the line in question which does not really exist on this side, but rather is the stacked wall seperation on the opposite side.
The stacked wall in question is an existing wall with a furred portion up past those windows.
Is there any way to get rid of this?
Tue, May 5, 2009 at 2:08:57 PM | stacked wall line visable on the wrong side?
Are you sure that this side is flush and the materials are the same?  VERIFY That.
Tue, May 5, 2009 at 3:22:09 PM | stacked wall line visable on the wrong side?
barcardi
The materials on the side pictured are the exact same, the materials on the back side are not, thus a stacked wall.
Wed, May 6, 2009 at 4:16:34 AM | stacked wall line visable on the wrong side?
tim123
4 Stars: 19 Votes
Do the faces line up exactly (this can be adjusted with the offset property)?  If one wall is just slightly out then the line will be visible.  You can also make the line go away by using the linework tool, with an invisible pen.
Wed, May 6, 2009 at 10:39:39 AM | stacked wall line visable on the wrong side?
barcardi
invisible pen?
Wed, May 6, 2009 at 10:51:58 AM | stacked wall line visable on the wrong side?
tim123
4 Stars: 19 Votes
The linework tool has a line style called 'invisible lines' that you can use to make unwanted lines disappear.
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
2013 - Stacked wall problems
Thu, Dec 12, 2013 at 8:23:39 PM
Stacked Wall Flipping to other side... help please
Wed, Dec 30, 2009 at 7:37:19 AM
Stacked Wall Dimensioning
Thu, May 27, 2010 at 3:48:25 PM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Page generation time: 1.7421
