64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Circuit Homerun
Tue, May 5, 2009 at 1:40:58 PM | Circuit Homerun
bnot3b
I am trying to circuit a room with the circuit number on each individual device and then show the home run with the panel and the circuit numbers (exp.  circuits 1,3,5 connected to panel H1.... ie....H1-1,3,5)
the problem is that i cannot find an option to circuit the devices independently from the homerun.  If i set the Prefix naming to panel name,  the devices will all have the panel name on them.  and if i set the prefix to standard, then the homerun will not have the panel name.
sorry if i didnt make much sense.
Thanks!
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:58 AM
Homerun arrows on elektrical wiring
Wed, Jul 21, 2010 at 3:40:15 PM
How to Wire Multi-Circuit Receptacles Within 1 Conduit?
Mon, Mar 21, 2011 at 1:19:07 PM
Homerun from junction box
Mon, May 14, 2012 at 10:08:42 AM
homerun tag
Thu, Jan 21, 2010 at 2:15:47 PM
Page generation time: 1.6152
