62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Void Blend not showing correct cut
Tue, May 5, 2009 at 9:37:38 AM | Void Blend not showing correct cut
akome555
Hello,
A cube mass I created with void blend on one side with triangular form on the half top of it and then meeting at a point down below on the middle of the edge. Upon cutting it with void blend, the graphical representation in incorrect. so even the one side of plane of the mass is incorrect. any help.
Tue, May 5, 2009 at 12:29:56 PM | Void Blend not showing correct cut
4 Stars: 203 Votes
May I ask why don't you create a solid blend instead a solid extrusion then use the void????
Tue, May 5, 2009 at 11:21:00 PM | Void Blend not showing correct cut
akome555
Thank you typhoon,
A solid blend is ideal, but i am creating a massing study for a faceted facade for a 16K s.m. gfa building. with several options in mind as to how would the different angular cut  could be made when put into actual documentation.  I try the void blend in order to immediately remove that particular void in any case it doesn't fit the design and back to its original basic form.
Using a void to create an opening in a swept blend?
Tue, Apr 6, 2010 at 12:03:28 AM
Why wont the void subtract from the solid blend
Thu, Sep 10, 2009 at 7:35:23 AM
VOID FORM says there is no geometry to cut.... [ 1 2 ]
Wed, Dec 17, 2008 at 12:52:27 PM
19
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Cut a Void out of i.e. 2x12 Roof If your EXPOSED Rafter tails are 6,8 etc.
Thu, Mar 6, 2008 at 9:16:45 AM
Page generation time: 20.1337
