80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Newbie trying to understand central files vs. import revit files
Mon, May 4, 2009 at 6:37:26 PM | Newbie trying to understand central files vs. import revit files
blakeye
I am a newbie to working with central files. I have received from an outside Architect a large revit file and need to add specific furniture and sign elements to the file.
I am trying to find an easy solution to using central files and what are the steps I should take in using this file?
Should I open the central file they sent and then re-save as a new file or should I import their central file as a revit link ?
What is the best way so I do not disrupt their files but allows them to import my additions back into the central file at their site?
Tue, May 5, 2009 at 6:55:04 AM | Newbie trying to understand central files vs. import revit files
You need to spend some time with your H E L P.  Look up worksharing first.  This will lead you to explanations of central and local files.  Then look up copy/monitor and linked files.
The best approach here would be a copy monitor process on both ends.
Deleting local files and copying files from central
Fri, May 23, 2008 at 11:28:56 AM
saving as non central models
Thu, Dec 12, 2013 at 10:17:31 AM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
Sun, Nov 7, 2010 at 6:21:01 PM
CENTRAL FILE back-up Files
Tue, Jan 29, 2013 at 1:26:28 PM
Linking Revit files
Fri, Jul 22, 2005 at 6:08:11 PM
Page generation time: 1.8033
