40 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Clean-up
Mon, May 4, 2009 at 4:01:37 PM | Wall Clean-up
johnsonsara
I'm having a problem with the wall cleanups.   I'm using 2009.  I have attached a picture to help.
Both walls are stacked walls.  I do not want the vertical band of red.  All colored CMU bands are to be horizontal and extend to the corner.  For whatever reason the vertical band of red shows up when walls are joined.  I have tried mitering and re-cleaning up the wall joins...even at different cut elevations.  Any suggestions?
Tue, May 5, 2009 at 9:33:17 AM | Wall Clean-up
travistlo
5 Stars: 2 Votes
try disallowing the joins, then use the Join geometry tool instead. This allows you more control over the exact location of the wall end.
Chatting it up on gmail - travistlo.j@gmail.com
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:24 AM
Wall clean-up
Fri, Nov 21, 2008 at 3:21:12 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:09 AM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:19 PM
Page generation time: 5.7038
