66 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> creating a cone
4 Posts No Rating |
Hey y'all, As a new revit user I am completely unaware how to make a cone-shaped building. The intention is to make a concrete cone. So i tried to sloped my walls. But i can't seem to connect them at the top point. I could only enter the desired sloping and then it would get a certain height. Which is a bit time-consuming, especially if i would like to alter certain aspects later on! Then I tried to make a mass with solid revolve. Which resulted in a cone (in the wrong direction, but I guess that's fixable). But how can I turn that mass into walls? Are there any good ways to do this? Any help is appreciated. greets, Rik
I would do the very top of the cone as a seperate element and join geometry for that portion. For the other, create a mass - solid blend, then use that and do wall by face.
4 Posts No Rating |
thanks! I tried to use the wall by face now, but it doesn't seem to have any depth. is that normal?
![4 Stars: 19 Votes](/images/stars_4.gif) |
No reason why this should not work. The image shows a cone created in the way that WWHub described, with a wall placed by face. Are you sure its not a curtain wall that you placed? If so you will need to apply panels.
4 Posts No Rating |
right! my bad. Thanks a bunch.
solid concrete cone |
Thu, May 7, 2009 at 9:27:53 AM
Curved / Cone style Roof |
Sat, May 25, 2013 at 4:03:11 PM
Cone roof mapping |
Thu, Mar 15, 2007 at 6:42:53 PM
Solid Blend problems |
Mon, Jul 20, 2009 at 4:04:05 AM
How to make a cone shaped building..? |
Thu, Mar 25, 2010 at 2:29:56 AM
Members: | 2017481 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
