105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> fill pattern alignment
Sun, May 3, 2009 at 12:25:23 PM | fill pattern alignment
jprado
i have created a custom fill pattern and applied it to a custom wall type, but when two of these walls appear together in elevation, the pattern does not align.  both walls are base constrained to the same level and attach to a sloping ceiling above.  see attached elevation.  any ideas how to align the pattern?
Sun, May 3, 2009 at 12:36:18 PM | fill pattern alignment
tim123
4 Stars: 19 Votes
Assuming that it's a model pattern, you can select a line in the pattern (use the tab key) and move or align or rotate it.
Sun, May 3, 2009 at 12:45:17 PM | fill pattern alignment
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jprado, see this: http://www.revitzone.com/index.php?option=com_content&task=view&id=752&Itemid=50
Sun, May 3, 2009 at 1:16:41 PM | fill pattern alignment
4 Stars: 203 Votes
Use the "Align" tool, see you HELP menu....
Sun, May 3, 2009 at 1:28:15 PM | fill pattern alignment
jprado
Thanks everyone. Tim's suggestion worked perfectly.  I'll check out the align option and other link.
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:21 PM
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:55 AM
Page generation time: 0.6012
