42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> PDF conversion
2 Posts No Rating |
Ive got some dimensions in PDF format that i need to get into Revit, how do i do this? any help?
And you want get into in Revit like what format????
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Hi fireman3101, one way could be to convert that file to a .dwg type file (you have to have a pdf to dwg converter to do that), then import it into your Revit file....
2 Posts No Rating |
nice. can you recomend a converer cuz the one i found converts it to some file type that dosent open in revit
Hi fireman 3101, try here: http://www.autodwg.com/pdf-to-dwg-converter/ ....the one i found converts it to some file type that dosent open in revit.....Most of these converters save the new files as .dxf, so what you have to do is to open your file in AutoCAD and save it as .dwg.Then you have to IMPORT that .dwg 'cause you can't open .dwg files in Revit.
.txt Conversion to .pdf |
Wed, Feb 8, 2012 at 3:43:28 AM
How to set custom unit conversion value |
Thu, Jul 17, 2014 at 5:27:32 AM
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND?? |
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names |
Thu, Apr 7, 2011 at 8:37:37 AM
pdf print |
Thu, Sep 25, 2014 at 6:04:04 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
