113 Users Online (111 Members):
Forums >> Revit Building >> Technical Support >> 3D line based hosted family template or solution
29 Posts No Rating |
I would like to host a series of 3D Line-Based Familes in walls, ceilings, floors, and roofs. I am looking for the capability of a 3D line based family being able to be re-sized in length, while being able to have it be hosted in other objects. Any thoughts?
A line hosted family is just that... If you want a face based family, use that instead. Maybe if you were more explicit on what you are wanting to do.
I am preparing to model a series of expansion joint covers.I would like to include a void form in the family to subtract from the host I insert the joint cover in to.
Changing the "length" to an instance parameter allowed me to adjust the extrusion as I would a line based family. See attached.
How would you modify a family from face-based or hosted to one that is not? |
Mon, Sep 26, 2011 at 8:39:50 AM
Is it possible to make a line-based family wall based? |
Wed, Jan 5, 2011 at 1:00:21 PM
Line Based Template File 9.1 |
Thu, Jan 10, 2008 at 3:47:33 PM
Family Typical Model based on line |
Mon, Dec 22, 2008 at 7:55:47 AM
Creating an expansion joint family |
Sat, May 2, 2009 at 10:57:03 AM
Members: | 2042307 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
