Forums >> Revit Building >> Technical Support >> 4d simulation and component schedule
118 Posts No Rating |
1st question: Has anybody successfully done it with Revit and NavisWorks? I've heard you have to use a scheduling software called "Primavera" to link the model to the tasks? 2nd question: What's the best way to export the Revit model to the list of schedules (like a break down of the building components)? Is it XML file?
yes with Navis, it is not to difficult you have to export pieces of the model though, ie duct work, mech pipe, plumbing (maybe break this one up), fire protection, electrical. Primavera works nicely although so does microsoft project. you can export your schedules to a delimited txt file that you can then open in xcel, you can also create an odbc database and go though route but it is a little more involved.
http://familyjewels.typepad.com/ |
- Absolutely. Lots of people have. As previously mentioned, you can do a the 4D scheduling of the elements a number of ways. Directly in Navisworks - slow, painful and not user friendly. By importing a presetup schedule from MS Project and then applying the schedule items to their various 3D counterparts. OR from Primavera - which is a lot more powerful than MS Project and detailed, as such generally the revit model hasn't been modelled appropriately to link first up and usually requires editing such as breaking slabs into 4 pours etc. Also, it requires continually exporting out of Primavera and relinking to Navisworks, where as Navisworks links directly to a MS Project file so no exporting required.
- Yes, ODBC can work or Multi Category schedule then export out to a .txt file and open in Excel.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
2 Posts No Rating |
this is an interesting discussion.. thank you for sharing [url=http://simulationrachatdecredit.org][color=#FFFFFF][u]simulation rachat de credit[/u][/color][/url]
2 Posts No Rating |
While simulating a project in 4D, Navisworks shows 0% (task start), and 100% (end of task) in the model. What do i do if i want to visualise 50% (part completion) of a task o be shown in the model. Pn- Schedule to Be attached in MSP For eg- activity X takes 5 days to complete, can navis works represent part completion( say 20%, 40%) as it simulates from day 1 to day 5
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:40 AM
18
Detailed Numbers for Green Building Studio Energy Simulation Report? |
Mon, Dec 16, 2013 at 5:40:02 AM
Help with Custom Schedule |
Thu, Feb 12, 2015 at 2:18:11 PM
Visuel simulation |
Tue, Nov 11, 2008 at 7:39:07 AM
Embedded detail component scale issue |
Mon, Oct 15, 2007 at 10:07:16 PM
Members: | 2097964 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
