97 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Custom Room Parameter tag
Thu, Apr 30, 2009 at 12:59:02 PM | Custom Room Parameter tag
line
Hi
I am setting up a room tag and I would like to add my own parameters, but they do not seem to work probably in my project neither can I pick them up in the room schedule?     Am I doing something wrong or is this not possible with room tags?
thanks.
Thu, Apr 30, 2009 at 1:09:13 PM | Custom Room Parameter tag
tim123
4 Stars: 19 Votes
It needs to be a shared parameter, not a family parameter for this to work.  The family parameter is the default when you add parameters.
Thu, Apr 30, 2009 at 1:15:48 PM | Custom Room Parameter tag
line
tim123, thanks alot it works!
Thu, Apr 30, 2009 at 3:22:40 PM | Custom Room Parameter tag
will2play
will2play Avatar
check out
http://www.aecbytes.com/tipsandtricks/2008/issue33-revitarch.html
if you really want to learn Reivt Family Creation
www.will2play.com
www.will2play.com
URL parameter in a room tag
Thu, Feb 18, 2010 at 3:55:56 AM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:41 AM
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:10 PM
Custom room Stamp/Tag in Revit
Sun, Oct 17, 2010 at 9:42:01 PM
room temperature parameter in room tag???
Wed, Oct 27, 2010 at 3:38:09 PM
Page generation time: 0.6782
