53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adding a material to a mass imported from Rhino
Tue, Apr 28, 2009 at 6:43:33 PM | Adding a material to a mass imported from Rhino
jutoft
Hey everybody,
I have a question about how I can add a material to a mass imported from rhino. I have been surfing around and I can't seem to find a answer ( I am a bit of a rookie though so I might have missed something obvious :D )
I have imported the geometry via a .sat file from rhino into a revit family file. I then click on the geometry and go to
1. element properties
2. visible
3. add parameter...
This opens the parameter properties menu, from here I choose
1. family parameter
2. set group parameter to materials and finishes
3. choose a name
This is where my problem begins though. The menu "type of parameter" is greyed out and fixed on "yes/no" rather than on "materials" as I need.I imagine that it might be because I have have a problem with the imported geometry?
 Am I trying to do something that can't be done or am I missing something in my workprocess?
I am using Revit Architecture 2009 (I hope I am posting in the right forum?) and am attaching the file in question
Any help would be greatly appreciated :D
Edited on: Tue, Apr 28, 2009 at 6:50:58 PM
Tue, Apr 28, 2009 at 8:11:18 PM | Adding a material to a mass imported from Rhino
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jutoft, look, when you import to Revit a model made in Rhino, you always will find its materials here: Settings-->Materials... (see image). Depending on the colors you gave to its components (i.e. blue for glass, etc.), you´ll find them with names like "Render Material 255,255,255" which will be assigned with a blue color, what you have to do is to assign a material to each component (see image). This is also effective to models imported from Sketchup, 3ds Max (both via .dwg type files) and AutoCAD.
Tue, Apr 28, 2009 at 9:52:41 PM | Adding a material to a mass imported from Rhino
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Rather than do this, I recommend going to settings-->Object Styles-->Imported and linking the layers to materials of regular naming.  This way you don't end up with materials that are specific to certain families.
Regards,
Chris.
Wed, Apr 29, 2009 at 2:45:13 AM | Adding a material to a mass imported from Rhino
jutoft
Thank you very much, that did it!
Fri, Oct 22, 2010 at 2:27:32 PM | Adding a material to a mass imported from Rhino
jimmyoloughlin
Is there a way to apply multiple materials within one import.  I successfully did what was said above, but was not able to apply different materials to different layers of my import.
Rhino imported as mass
Tue, May 7, 2013 at 12:58:01 AM
Rhino to Revit Conceptual Mass
Tue, Sep 10, 2013 at 8:15:46 AM
Can't Make Type - curtain wall panel on imported rhino mass
Mon, Sep 27, 2010 at 8:02:48 AM
URGENT HELP! Rhino polysurface to Revit Mass
Fri, Nov 20, 2015 at 11:27:54 PM
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:10 AM
Page generation time: 0.6819
