67 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Perspective line weight
Tue, Apr 28, 2009 at 4:59:03 PM | Perspective line weight
Martha
Hi! I want to change the weight of perspective lines and I can't remember where to do it. I don't find the category in Object Styles or VG. Anyone can help me?
Thanks!!!
Tue, Apr 28, 2009 at 8:22:25 PM | Perspective line weight
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi Martha, go to Settings-->Line Weights...-->Perspective Line Weights.
Sat, May 2, 2009 at 10:43:00 AM | Perspective line weight
Martha
Thanks for answering Erland!
I knew where the styles are, but I don't know how to set one!
Let's see if I can put things clear (I don't know if my English is good enough): There is one of the 16 styles that is active by default. How do I know wich one? or  How can I change it (shall I go to Object Styles or maybe Line Styles?)?
My problem seems to be that I can't find the correspondant category in the dialog boxes.
Sat, May 2, 2009 at 1:03:44 PM | Perspective line weight
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hola Martha, creo que se nos hace más fácil en español...si te entiendo bien, tu quieres realzar más las lineas de los objetos en perspectiva dependiendo de la categoria, o no se si lo que quieres es cambiar el grosor de las lineas dependiendo del plano. Si es lo primero te vas a Object Styles-->Walls, pero te cambiará todas la lineas (ve la segunda imagen), pero si es lo segundo, puedes usar el Linework tool, aunque en perspectiva es más difícil controlarlo (ve la imagen). Bueno espero que te haya entendido, sino dejamelo saber..saludos hasta Uruguay....
Edited on: Sat, May 2, 2009 at 1:08:11 PM
Sun, May 3, 2009 at 9:53:36 AM | Perspective line weight
Martha
Hola Ernesto.
Lo que quería hacer era dar un poco más de "peso" a las líneas en vistas de perspectiva, pero, por un error conceptual, buscaba una categoría de "perspective lines" (que no existe!!!). No me había dado cuenta de que era, simplemente, hacer un "override" de vista para las perspectivas en la categoría de modelo correspondiente (si es una vista en perspectiva, son "perspective lines"...!)
Este software es tan complejo, que a veces hace que uno se complique solo!!!
Gracias por darme la pauta y un abrazo para tí y para tu hermoso país.
Viewport Title Line Weight
Wed, Mar 12, 2008 at 8:14:53 PM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:30 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:59 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:56 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:54 AM
Page generation time: 0.6754
