Forums >> Revit Building >> Technical Support >> Error Message: "Circular Chain of Reference" - help requested!
Tue, Jul 12, 2005 at 2:39:00 PM | Error Message: "Circular Chain of Reference" - help requested!
dorri
I've run into this problem a number of times. Basic example: I have a sweep whose path runs along three sides of a rectangle. Along the fourth side I try to run another sweep. The beginning and end of the second sweep path meet the beginning and end of the first sweep path. Revit lets me finish drawing the path, but as soon as I hit "finish sweep," an error message comes up referring to a "circular chain of reference," and I cannot complete the second sweep. I'm guessing this is related to the fact that together, the two sweep paths make a closed loop, but I don't understand why this is a problem and how to solve it. Any suggestions are most welcome! Thanks.
Tue, Jul 12, 2005 at 4:35:57 PM | RE: Error Message: "Circular Chain of Reference" - help requested!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Would need a broken down version of the file in order to comment as it could be any number of things.
Tue, Jul 19, 2005 at 4:51:36 PM | RE: Error Message: "Circular Chain of Reference" - help requested!
dorri
Unfortunately, I was unable to elicit the same error message from my problematic project. I would appreciate if you would read over a more detailed description, however, to see if you know the problem. I was creating a family for double hung windows, and using a series of sweeps to add each jamb, sash, etc... my problem arose when I tried to complete the sash around a single glass pane. The sash had a different structure along one of its sides, so I attempted to use two separate sweeps- their paths together formed a complete rectangle. From what I gathered, the problem was that two separate sweeps were creating one closed path, because the problem was resolved when I offset the sweep paths from each other by a small distance. Could this touching of paths have been the problem? Why would this condition be problematic in Revit? Thanks.
Tue, Jul 19, 2005 at 6:31:03 PM | RE: Error Message: "Circular Chain of Reference" - help requested!
JoeDrevitO
Wherever I have had a "Circuilar Chain of References" error it has been when I create a line locked in some way to another line, then i take the second line and try to lock it to the first. Its just a logical circle. Usually I just to a temporary hide on the other line and work without it for a bit. Not sure how that relates to your problem though.
Wed, Jul 20, 2005 at 12:24:13 AM | RE: Error Message: "Circular Chain of Reference" - help requested!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As Joe outlined it will be to do with how the paths were constrained. As a general rule when i make families i don't hit the automatical locks when drawing a sketch as quite often these are constraining the elements to other elements as opposed to reference planes. If you lock sketch lines to reference planes and not to each other you should not have this issue. Any parametrics should always be applied to the reference planes. HTH.
Thu, Nov 24, 2011 at 9:34:08 PM | Error Message: "Circular Chain of Reference" - help requested!
confidentialdoor
hi, I am farhad from bangladesh. I am a team leader here in bangladesh. I work together with arround 30 to 40 member here. I can solve that problem by using join command. I think this is only the solution to minimize this error. by this method I solved "Circular Chain of Reference" error several time. if this method is not enough then plz ask me by, skype id. rezanew1 or fullconfident.1@gmail.com
Wed, Apr 23, 2008 at 12:21:54 AM
"Chain of Circular References"
Mon, Nov 13, 2006 at 8:13:43 AM
2008 file giving "circular chain of ref" error on 2009
Thu, Apr 24, 2008 at 11:20:20 AM
Wish List - Kill Circular Chain of references
Thu, Apr 10, 2008 at 1:51:30 PM
Circular chain of events
Mon, Sep 11, 2006 at 9:23:06 PM
Page generation time: 0.8115
