72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exterior and interior walls
Tue, Apr 28, 2009 at 9:57:31 AM | Exterior and interior walls
fastjohnnyz
 Question:
I have a 2 story house w/ a gable roof. I have a 1 story garage w/ a gable roof. Ext. walls are EIFS over studs. I have the garage butting in to the side of the house. Now the ext. wall above the garage gable roof and below the house gable roof is eifs, which is good. But my problem is, how do I cut out that same wall plane thats between the house and the garage and below the garage gable roof so that I can change it to an interior gyp wall? By the way, the roofs are at 9/12 slope. Looking at the front of the house the garage is on the right side. Both roofs slope from front to back.
Thanks,
Johnny Z
Tue, Apr 28, 2009 at 10:39:48 AM | Exterior and interior walls
travistlo
5 Stars: 2 Votes
you can attach the wall base to the roof, you can edit the profile sketch of the wall in elevation.
Chatting it up on gmail - travistlo.j@gmail.com
interior walls in foundation
Wed, Nov 8, 2006 at 11:32:50 AM
DWG Export Interior/Exterior on others than walls?
Wed, Nov 17, 2010 at 1:57:27 AM
Interior/Exterior Lighting
Fri, Oct 8, 2010 at 12:53:06 PM
Maintaining interior dimensions when changing walls
Mon, Mar 16, 2009 at 11:19:26 AM
Walls keep moving
Fri, Apr 11, 2008 at 10:04:18 AM
Page generation time: 0.8151
