67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Printing in Revit
Tue, Apr 28, 2009 at 9:51:46 AM | Printing in Revit
Runyank
Hey guys,
The firm I work for just recently started issuing construction documents all in Revit.  I seem to be having some troubles in the printing department.  Basically, I will print my stuff out using the batch DWF 2D print, then convert them PDF format.  Well the DWF's look great (lineweights, etc), but when I convert them, all my lineweights seem to be really light and almost half toned in PDF.  I'm not sure what is going wrong with this, also, is there a way I can do a batch print to PDF?  The only way I see now is printing each sheet to PDF individually (which takes forever).
Tue, Apr 28, 2009 at 10:19:14 AM | Printing in Revit
Why are you doing that?
We use cute pdf (free) and you can click on the checkbox to print all the sheets to one file ... done... or to seperate files if you want them.
In addition  - Both 2009 and 2010 have a batch plot extension available from AutoDESK
Tue, Apr 28, 2009 at 10:50:39 AM | Printing in Revit
Runyank
Like I said, fairly new to doing construction documents in Revit, usually we would upload PDF's created from AutoCAD, and attach our model to the same upload.  Your way sounds much easier though, thanks for the input.
Printing Query
Wed, May 23, 2012 at 7:54:09 AM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:02 AM
printing press
Wed, Dec 29, 2010 at 11:28:45 AM
Printing Lighting Plans in Revit MEP
Mon, Mar 14, 2011 at 9:20:36 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:16 AM
18
Page generation time: 1.7729
