1 Posts No Rating |
Hello, I'm wondering if it is possbile to copy the view crop and horizontal view breaks from one view to another. Is there a way to do this in revit, or a relatively painless way to align the crops of several views. So far, I've just been eyeballing it, but the results are not really satisfactory. In my case, I have a series of wall sections of various conditions in my building. For a typical wall section I have two horizontal view breaks because I only want to show the condition at the floor, the ceiling, and the slab above. There are various different cove, soffit, and ceiling/wall connections in these various sections. I want to put them all on a sheet, and have the detail crop regions, view breaks, break lines (...etc) align on the sheet. Does that explanation make sense? Well, if the above isn't confusing enough, take a look at the horrible ascii illustration below. Any thoughts? Thanks in advance! -bradidea ---------------------- || || || -v- -v- -v- || || || ---------------------
Place the views on a sheet. Add detail lines in paper space where you want a break in the view. Now activate the view and eyeball the breaks. You can nudge your break annotation line/mask using your arrow keys to get the break line visually to line up. The more you are zoomed in, the smaller the nudge increment.
