134 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How Do I Get Windows Around Curved Bay? Image Attached.
Sun, Apr 26, 2009 at 6:59:40 PM | How Do I Get Windows Around Curved Bay? Image Attached.
ksmith
Hi guys. I'm struggling in getting windows to fit around a curved bay. When I try to insert a window it just doesn't look righ at all. I have attached an image of the bay I'm trying to get the windows around. The only way so far that I have been able to get some sort of result  is by taking the bay all the way up to the wall plates on second storey level and then inserting the windows but the problem then is that the the external brick wall that is behind the bay stops the windows from becoming transparent.
Any ideas on the best way to get these windows looking right?
Thanks
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Sun, Apr 26, 2009 at 8:32:34 PM | How Do I Get Windows Around Curved Bay? Image Attached.
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi ksmith, one way you can try is to connect your curved wall to the second level, then split it with the height of the window you want and then change it to a "Curtain Wall:Storefront".....
Mon, Apr 27, 2009 at 5:14:19 PM | How Do I Get Windows Around Curved Bay? Image Attached.
ksmith
Thank you for that! Appreciated.
Triangular bay windows
Wed, Feb 16, 2005 at 8:01:14 AM
Roofing bay windows
Wed, Mar 23, 2005 at 12:28:30 PM
Box Bay Window
Tue, Aug 19, 2008 at 3:43:39 PM
Bay window component made of nested walls and windows?
Fri, Aug 24, 2007 at 8:30:13 AM
Cavity Wall Around Bay Not Showing Correct Detail
Sun, Jan 17, 2010 at 3:50:14 PM
Page generation time: 1.2620
