29 Users Online (28 Members):
Forums >> Revit Systems >> Technical Support >> HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
89 Posts No Rating |
hi all, i am using a vista 64bit 2009 revit version when exporting an avi i only have the choice between four codec versions i used the intel iyuv. it works and the avi produced will work ok on the vista machine but creates problems on other machines. i was told by my dealer that when i install an other codec, that codec then automaticly becomes available in the revit dialog box. (i installed divx) no such luck however does anybody, including revit know how this can be done current set up is very poor and the avi's can be guanteed to work on a clients machine, which is rather embarrassing. thanks so much, bob.
The best approach is to do the compression outside of Revit. Export out as "Full frames uncompressed", then you can use a wide array of software, some free, to do the compression. I prefer Camtasia Studio, but you could also use Windows Movie Maker or a number of others...
Regards,
Chris.
thanks mate, that was a promt responce very much appreciated have not tried as yet robert
2011 Revit Architecture Export Walkthrough CODEC |
Tue, May 18, 2010 at 9:43:10 AM
Uncompress Walkthrough Codec Problem |
Thu, Aug 13, 2009 at 11:45:50 AM
rendering help please |
Thu, Apr 5, 2007 at 12:57:03 AM
Revit MEP 2009 family to be used in Revit Architecture 2009 |
Fri, Feb 6, 2009 at 8:09:24 AM
Walkthrough problems in Revit 2012 Win 7 64 bit |
Thu, Sep 29, 2011 at 6:07:53 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
