73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> House and Detached Garage Revit 2009
Sat, Apr 25, 2009 at 2:23:30 PM | House and Detached Garage Revit 2009
2005Mark
3.5 Stars: 2 Votes
What is the best way to draw a house and also a detached garage that is at an angle to the house on the plot. If I draw the garage at say 25 degrees to the house then all its dimensioning will be at 25 degrees.
There must be a simple answer
Cheers
Mark
Sat, Apr 25, 2009 at 6:16:46 PM | House and Detached Garage Revit 2009
You can rotate the view of the garage.  From within that view, turn on the crop regions, pick that and then the rotate command, you can now rotate the view to the angle you want and it will not rotate the model elements.
Sat, Apr 25, 2009 at 6:18:03 PM | House and Detached Garage Revit 2009
BTW ,  this is all explained very well in the HELP.  Learn to use the search in HELP.  If you had entered rotate, you will find a topic on rotating a view.
Sun, Apr 26, 2009 at 8:43:40 AM | House and Detached Garage Revit 2009
2005Mark
3.5 Stars: 2 Votes
Thank you,
I must say I do shy away from the HELP as this forum is so good.
I must try better.
Thanks again.
Mark
inserting floor plan into sheet
Tue, Feb 28, 2006 at 7:01:11 PM
Exterior and interior walls
Tue, Apr 28, 2009 at 9:57:31 AM
How Do I Create A Lean To Roof Over A Garage
Thu, Jan 15, 2009 at 3:31:32 PM
12
taking an elevation of a linked model
Tue, Mar 4, 2014 at 11:57:17 AM
Area Plan - merge or combine areas?
Mon, Sep 9, 2013 at 4:32:01 PM
Page generation time: 2.2489
