36 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> My Floor Plan Is Not Showing In Some Views
Sat, Apr 25, 2009 at 5:54:19 AM | My Floor Plan Is Not Showing In Some Views
ksmith
I've set up my levels etc, but my floor plan doesn't show in some views. This is making it hard for me to see where  I am building my walls. To explain, I have built
footing walls which are set from -600
start of facing bricks -150
ground floor level 0
dpc level 150
I started drawing my floor plan using lines in the footing walls view at -600 and the the trench block walls I have used show fine. I then switch to start of facing bricks view at -150 and I can see the floor plan that I was working from in footing walls view which makes it easy for me to build the two courses of brick I want for that view.
The problem is when I switch to ground floor level view at 0 because when I do this I no longer see the floor plan that I have been using as a reference from the previous views so I can't see where  I am building on from my walls.
Is there an easy way to rectify this?
Thanks, Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Sat, Apr 25, 2009 at 8:40:34 AM | My Floor Plan Is Not Showing In Some Views
4 Stars: 203 Votes
in that view write VP then in the View Range change the View Depth...
Sat, Apr 25, 2009 at 1:54:42 PM | My Floor Plan Is Not Showing In Some Views
ksmith
Many thanks for that Typhoon! Greatly appreciated.
plan callout showing up under Floor PLans in project browser
Thu, Apr 16, 2015 at 1:48:05 PM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:11 AM
section line continuity between floor plan views
Thu, Aug 31, 2006 at 4:54:21 PM
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:05 AM
Floor plan showing ceiling fixtures and wiring to switches
Wed, Feb 18, 2009 at 2:49:45 AM
Page generation time: 1.2177
