48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> truss not visible on framing plan
Fri, Apr 24, 2009 at 1:45:34 PM | truss not visible on framing plan
bshearon
I installed a Warren truss attached to roof. It is visible in elevation, section, and 3d. When you hover over the line on the plan it appears, but it is not visible when I am looking at the roof framing plan. I have checked the view range and it appears to be correct.
Fri, Apr 24, 2009 at 1:50:22 PM | truss not visible on framing plan
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
is it showing as just linework? I am not familiar with the family you are using but perhaps changing the detail level from coarse to fine may do the trick?
Fri, Apr 24, 2009 at 3:20:04 PM | truss not visible on framing plan
bshearon
I want my view on course. I want the joists, beams and trusses to show as a single line. If I change to fine, the truss is visible but it shows multiple lines for the truss. Don't understand why beams and joists are ok and not the truss.
Fri, Apr 24, 2009 at 3:30:24 PM | truss not visible on framing plan
alabaster2513
3.5 Stars: 25 Votes
post a copy of the truss family you are using.
Mon, Apr 27, 2009 at 4:28:31 PM | truss not visible on framing plan
bshearon
Here is the truss family.
Grey out Truss
Thu, Jan 5, 2006 at 10:04:53 PM
Revit 2012 Truss System (framing members not showing)
Wed, May 9, 2012 at 9:25:34 AM
Framing Plan Objects Visiblity (2008)
Wed, Oct 17, 2007 at 6:21:05 PM
Members of the truss are not visible after rendering
Sat, Jun 1, 2013 at 11:01:31 PM
roof truss install
Tue, Feb 10, 2009 at 9:00:57 PM
12
Page generation time: 1.2675
