40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> GRADED TOPOSURFACE AT RETAINING WALL
Mon, Jul 11, 2005 at 8:35:15 PM | GRADED TOPOSURFACE AT RETAINING WALL
pholzberger
I'm having a lot of trouble achieving a successful graded toposurface at retaining walls, particularly where revit has generated a lot of points from an existing contour survey. I find that i have to create a very large number of new points to get anything that even remotely resembles an accurate surface. Are there any shortcuts or alternative techniques?
Wed, Aug 9, 2006 at 2:46:10 PM | RE: GRADED TOPOSURFACE AT RETAINING WALL
NewBe
Did you ever figure this out?
Wed, Aug 9, 2006 at 3:03:28 PM | RE: GRADED TOPOSURFACE AT RETAINING WALL
NewBe
Here is a JPG of what I am trying to get done. How do you remove the topo down to the floor level so that the door and deck are not buried. Thanks
Wed, Aug 9, 2006 at 3:18:34 PM | RE: GRADED TOPOSURFACE AT RETAINING WALL
moxierawk
if the topo is at the right height hopefully it is if you took it from an imported civil drawing. it's a matter of what the house should be at for it's z height. Look at it in elevation and select everything you want to move up. Type in the new height on the datum. It's at 0. If your topo is poking through the building which in most cases it does unless you have a super flat surface, use the pad command under site and set it's height under the basement height so that way it blocks out the surface from coming in.
Wed, Aug 9, 2006 at 3:21:57 PM | RE: GRADED TOPOSURFACE AT RETAINING WALL
moxierawk
to make a better surface it is better that you have closed splines or plines. i draw it in autocad then give it it's z height. go through and do a laywalk making sur everything is closed and joined. that way seemes to make it the best and not have to bs it's topo like it does.
Sat, Aug 19, 2006 at 5:29:13 PM | RE: GRADED TOPOSURFACE AT RETAINING WALL
NewBe
Still trying to figure out how to do this. I tried the Building Pad but it doesn't alow any slope and shows a line in the drawing were the pad ends. Grading does work because it wants to slope everthing. I need a clean cut. I made the walls retaining but it appears to have no effect. Why are they retaining IF THEY DON'T RETAIN anything! Any more ideas? Thanks in advance for any help.
Fri, Jan 30, 2009 at 1:22:33 PM | GRADED TOPOSURFACE AT RETAINING WALL
ddarcyy
i know this was posted two years agom but was anyone able to answer NewBe's question? do retaining walls "retain" the topo or do we have to manually manipulate the topography ourselves?
Fri, Jan 30, 2009 at 1:27:10 PM | GRADED TOPOSURFACE AT RETAINING WALL
ddarcyy
Fri, Jan 30, 2009 at 1:46:17 PM | GRADED TOPOSURFACE AT RETAINING WALL
ddarcyy
nevermind. "Split Surface" is the way to go to make voids and whatnot in your toposurface. yay.
Fri, Jan 30, 2009 at 2:16:29 PM | GRADED TOPOSURFACE AT RETAINING WALL
Manny
3.5 Stars: 6 Votes
its ok as long as you don't have to create a cut/fill schedule, if you split and delete it will not be included in the schedule
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
Toposurface Graded Regions
Fri, Jul 19, 2013 at 8:28:06 AM
placing parking stripes on graded toposurface
Thu, May 10, 2007 at 7:44:34 AM
Revit Architecture 09- Topography and Retaining Wall
Mon, Oct 12, 2009 at 4:15:33 PM
Creating curved retaining wall that aligns to topography...
Thu, Dec 22, 2011 at 12:30:03 PM
Page generation time: 1.6208
