80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Why do walls turn gray in renderings? color shows in shading w edges...
5 Posts No Rating |
The material color I assigned to the walls and chairs shows up in color shading with edges. Why do my walls and chairs turn gray when I render?
Hi sunshineeyes, if I understand correctly what you want, you´re attempting to do a render but you are not really assigning material to the wall(s), only changing the colors to your shading graphics (see images). About the chairs, make sure that you are not using previous family versions (that´s why they could be rendering gray).
5 Posts No Rating |
Hi erland73, Thanks for replying. I feel kind of embarrassed. I had a special wall finish that I attached to the walls. I thought that I waited to attach it until I saved it on the computer but it turns out that I assigned it with a path to a flash drive so since the flash drive wasn't in the computer when I went to render ....it couldn't find the path. As for the chairs changing all the color settings instead of just assigning the primary color resolved the issue. Thank you for your help. I appreciate it.
5 Posts No Rating |
Edited on: Thu, Apr 23, 2009 at 10:27:35 PM
Shading w/ Edges Color Differences |
Thu, Jul 23, 2009 at 2:18:43 PM
Doors displaying as gray in Shading with Edges |
Thu, Aug 6, 2009 at 3:46:42 PM
shading with edges problem |
Wed, Nov 17, 2010 at 6:49:49 AM
Shading with edges in plan |
Mon, Sep 8, 2008 at 4:18:14 AM
Gray walls |
Tue, Jun 13, 2006 at 1:07:37 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
