71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Gutter with no mitre joints
Thu, Apr 23, 2009 at 12:06:34 AM | Gutter with no mitre joints
Francis85
Sorry if this has been asked before but I looked around and couldn't find anything specific to my problem.
 I'm using a fascia sweep to add gutters to my roof. My gutter is a wide cylindrical shape. (see picture) But roofs have varying angles and most times the corners of the gutter do not mitre. If they do it comes out quite strange. I have tried sweeping it all at once to no avail & I have also used the mitre option with no reults.
 Any help would be appreciated
Cheers
Thu, Apr 23, 2009 at 7:37:35 AM | Gutter with no mitre joints
If this is a roof edge sweep, you can place them sequentially and they will cleanup.  If you have one already placed, you can click on it and add segment to make that continuous.
I can't tell from what you have posted but are you putting a gutter on a rake edge?  I don't think Revit will put a gutter on that.
Thu, Apr 23, 2009 at 5:40:52 PM | Gutter with no mitre joints
Francis85
Yes, raked edge. Hence adding the gutter with a fascia sweep.
Adding them in sequential order almost worked on all the joints, but it's a little hit and miss on the coners that are larger then 90 degrees.
Any other suggestions?
Fri, Apr 24, 2009 at 5:06:20 PM | Gutter with no mitre joints
jarosa
jarosa Avatar
4 Stars: 5 Votes
You may have to create a family to make the odd mitre. In real life this is a problem and i think it translates through with Revit. Revit can't calculate compound mitres very well.
Give us a 3d view to confirm your situation.
John
Gutter display on roof plan
Mon, Jun 11, 2007 at 3:47:21 PM
Gutter but what about gutter downpipe?
Mon, Feb 22, 2016 at 12:31:57 AM
Annoying gutter join
Mon, Aug 4, 2014 at 6:38:10 PM
CUSTOM GUTTER PROFILE
Wed, Mar 27, 2013 at 1:59:53 PM
sloping gutter
Thu, May 10, 2007 at 6:16:35 PM
Page generation time: 0.7168
