150 Users Online (149 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2010 Tutorials
Wed, Apr 22, 2009 at 6:42:26 PM | Revit 2010 Tutorials
coreed
coreed Avatar
4 Stars: 16 Votes
i have downloaded the Revit tutorials and training files as always. followed the readme.txt.  copied the  download tutorial chm over the  existing one. this time is was not an .exe file. but for some reason my tutorials will not function when i go to help and select Tutorials. i get what is in the attached image. does anyone have any insight on this issue that may help me. i can't see whats wrong.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Apr 22, 2009 at 6:47:48 PM | Revit 2010 Tutorials
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I have seen that but only when the chm file is opened from my network. try jst pasting it onto your desktop and opening and see if you have the same issue.
Thu, Apr 23, 2009 at 6:16:25 AM | Revit 2010 Tutorials
coreed
coreed Avatar
4 Stars: 16 Votes
thanks, i give it a try when i get back to the office
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 24, 2009 at 12:26:36 AM | Revit 2010 Tutorials
coreed
coreed Avatar
4 Stars: 16 Votes
i have solved my Revit Tutorial problem. it must be windows vista thing. windows vista had put a block on my tutorial chm file for security reasons since it was from another computer. if you go to the directory where the file is located, select it, right click and select properties you will see that the file is blocked. click the remove block button and everything works fine.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 24, 2009 at 7:17:14 AM | Revit 2010 Tutorials
coreed,
Were there new tutorials for 2010?  I didn't see any in the subscription area.  They all looked like 2009.
Fri, Apr 24, 2009 at 8:45:04 AM | WWHub
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2009-04-24 07:17:13
coreed,
From what i had time to look at they are new tutorials. i won't be in the office today. but i will verify when i get a chance.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 24, 2009 at 11:37:35 AM | Revit 2010 Tutorials
alabaster2513
3.5 Stars: 25 Votes
Yeah the new Revit tutorials are different from years past, different index and model to work on. All of then datasets are available from autodesk.com
Tue, May 5, 2009 at 12:33:40 PM | Revit 2010 Tutorials
YoKanski
The same solution works for XP also. I just tried it.
Fri, Aug 13, 2010 at 7:33:25 AM | Revit 2010 Tutorials
Pele
Pele Avatar
Hey thanks it worked for me too, on Revit & ADT
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Revit 2010 Video Tutorials
Wed, Dec 30, 2009 at 9:25:23 AM
Revit Arch 2010 Interface Tutorials
Mon, Dec 21, 2009 at 2:13:19 PM
Revit 2010 Tutorials?
Sun, Oct 4, 2009 at 1:01:38 AM
14
SITEWORKS FOR REVIT - Tutorials
Thu, Oct 9, 2014 at 2:20:58 PM
Massing Tutorials (Revit Architecture 2013)
Thu, Sep 13, 2012 at 4:17:48 AM
Page generation time: 2.7124
