55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> is there anyway to put windows in curtain walls
Wed, Apr 22, 2009 at 3:15:21 PM | is there anyway to put windows in curtain walls
jdivina
Have a curtain wall and want to put an awning in the bottom half of the curtain wall.  Is there a awning window for the curtain wall out there that i can use
JD
Wed, Apr 22, 2009 at 3:27:46 PM | is there anyway to put windows in curtain walls
jdivina
nevermind problem solved
duh!!!!
JD
Wed, Apr 22, 2009 at 3:30:01 PM | is there anyway to put windows in curtain walls
When you post a question on RevitCITY then discover your own answer, we ask that you contribute to the knowledge base by posting your solution ... please.
Thu, Apr 23, 2009 at 12:26:29 PM | is there anyway to put windows in curtain walls
jdivina
oh ok
well it was nothing big
it was pretty much common sense
just like how you put a door in a curtain wall
but i just had to find the right window
thats all
JD
Thu, Apr 23, 2009 at 12:39:48 PM | is there anyway to put windows in curtain walls
coreed
coreed Avatar
4 Stars: 16 Votes
no solution is to simple to post.
Thanks for taking the time.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:02 PM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:07 PM
Curtain walls vs doors & windows
Sat, Oct 15, 2016 at 4:16:01 AM
scheduling windows and curtain walls together
Wed, May 11, 2011 at 7:52:32 AM
Curtain walls
Mon, Nov 7, 2011 at 10:28:34 AM
Page generation time: 1.1901
