Forums >> Revit Building >> Technical Support >> Combination Deck -Q-deck Floors
Hi all, someone knows a way to createa combination steel-concrete floor or a Q-deck floor, including the direction of the steelprofile. Grtz Ce
Like this floor type 4 example? See attached! GrtzCee
No one uses floors like these? Grtz Cee
I think the quick way to do that is create-in place a "void" in the category "Floors" and cut the slab like you want....
Even in Structure there is not a parametric floor system for this? Because if I draw it as an in-place family, it's not fully interactive, I would like to place it as a family, which show the direction of the corrugation, and parametrically the profile [height]: 50, 80, 140 like:http://www.metaldeck.ltd.uk/floordecking.asp http://www.metaldeck.ltd.uk/home.asp http://www.d-macindustries.com/floor.htm http://bluegem.en.made-in-china.com/product/VMpnUkYcJlhD/China-Floor-Decking-Sheet-YX75-200-600-.html
Check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=13664 Sorry for the videos but was gonne....
Aligning Deck Symbol Annotation to Deck Edge |
Tue, Sep 4, 2007 at 12:21:21 PM
Metal Structural Deck on Floor |
Tue, Jul 12, 2005 at 10:06:30 AM
Metal Deck Diaphram |
Thu, Jan 4, 2007 at 11:27:06 AM
stair railing baluster properties not consistant with deck rail |
Wed, Sep 3, 2008 at 11:08:33 AM
deck profile is not loaded |
Mon, May 5, 2008 at 1:29:02 PM
Members: | 2101676 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
