40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cut end of Stair
Wed, Apr 22, 2009 at 1:35:03 PM | Cut end of Stair
jarosa
jarosa Avatar
4 Stars: 5 Votes
I want to create a void or cut the corner of this monolithic stair to meet the slab where it extends past brick veneer only. I'm not able to get a void or cut geometry to work.
Revit 2010
John
Wed, Apr 22, 2009 at 1:48:14 PM | Cut end of Stair
And I don't think you will.....
Either do your stairs as an in-place family extrusion using the side profile you want
                           or
Start you stair one step up and modify the end of your slab with a slab edge sweep ... or something in-place.
Wed, Apr 22, 2009 at 1:54:52 PM | Cut end of Stair
4 Stars: 203 Votes
Did you change the "Extend Below Base"????
Wed, Apr 22, 2009 at 2:26:53 PM | Cut end of Stair
jarosa
jarosa Avatar
4 Stars: 5 Votes
WWhub, You confirmed that i can't void or cut geometry. Thanks.
Typhoon, that worked. I tried it before. Wheni did it the first time i put in a positive number and it messed up the stair. I got it now. Set extend below base to -5" I had to split and move walls so they could attach to the stair and slab and used a little linework.
Thanks guys,
John
Wed, Apr 22, 2009 at 2:39:11 PM | Cut end of Stair
Thanks typhoon .. I didn't see this one.
Wed, Apr 22, 2009 at 3:15:26 PM | Cut end of Stair
4 Stars: 203 Votes
Jarosa, You welcome
WWhub, you don't need that man....
I'm glad the problem is solved because if you create a "In-Place" in 2010 you can find the category "Stairs" so the void don't work, the cut-geometry can't work...
Wed, Apr 22, 2009 at 3:29:21 PM | Cut end of Stair
jarosa
jarosa Avatar
4 Stars: 5 Votes
Hey guys,
Just for sits and giggles here is the rendering. We are replacing the existing stair. I'm doing coordination drawings for the field. We are reusing the existing rails (not shown) because they are somewhat ornate. We have to make sure the elevations and dimensions are right on so when we bring the rails back on site after rehab it all comes together. Meanwhile i'm working out the details. Revit is nice for this. It helps us pick up details now and reduce guesswork in the field.
How's Revit 2010 going for you?
Thanks again for the help.
John
Wed, Apr 22, 2009 at 3:34:31 PM | Cut end of Stair
4 Stars: 203 Votes
I'm at the begining with this "Fabulous" (i think this is the word) version...
Wed, Apr 22, 2009 at 3:51:09 PM | Cut end of Stair
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Yeah man, that´s the word.....I like RAC 2010........
Edited on: Wed, Apr 22, 2009 at 3:53:08 PM
Spiral Stair I Need to start at 90 degrees and end at 90 degrees [ 1 2 ]
Wed, Feb 19, 2014 at 12:40:39 PM
15
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:09 AM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:54 AM
stair path to show full length of stair REVIT 2015
Thu, May 28, 2015 at 3:59:55 PM
Stair Cut Line : Double Line
Mon, May 18, 2015 at 3:19:09 AM
Page generation time: 2.2207
