34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Removing individual vindowsegments from a curtainwall?
Wed, Apr 22, 2009 at 7:20:11 AM | Removing individual vindowsegments from a curtainwall?
McGade
Hi Guys again
 Now i have a problem with deleting individual glass segments from my curtain wall. I simply cannot press delete to remove them. Does anybody know how?
 Kind Regards Peter Gade
Wed, Apr 22, 2009 at 7:22:03 AM | Removing individual vindowsegments from a curtainwall?
Which components do you want to remove?
You can delete mullions - you can replace the panel with an empty system panel ... you can edit the profile of the curtain-wall and sketch a hole in it of any shape.
Wed, Apr 22, 2009 at 7:31:30 AM | Removing individual vindowsegments from a curtainwall?
McGade
it doesnt seems to let me chance individual panels. It wants to chance the whole deal?
Wed, Apr 22, 2009 at 7:36:40 AM | Removing individual vindowsegments from a curtainwall?
You have placed a fully automatic curtainwall.... all of the controls are setup in the type.  Setup a curtainwall to one that is not automatic  ... turn off the spacings/mullion and panel types / etc. then change this curtainwall to that type and pick the option that keeps all the components in place.... now you can change individual elements.
Wed, Apr 22, 2009 at 8:20:08 AM | Removing individual vindowsegments from a curtainwall?
McGade
I got i Smile thanks m8
Curtainwall edit profile
Fri, Jun 12, 2020 at 7:48:21 AM
Converting curtainwall into wireframe
Wed, Jun 13, 2012 at 2:08:44 PM
12
Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
Fri, Oct 26, 2012 at 11:45:05 AM
Custom Curtainwall Tag from View Tag
Tue, Feb 26, 2008 at 9:17:54 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
Page generation time: 0.5503
