Forums >> Revit Building >> Technical Support >> parameters for embedded families
Hi. I am using Revit 2009. My question concerns families with imbedded families (components). I have designed an elevated walkway module which is made up of a floor piece cradled between 2 posts. The posts are an imbedded family containing the wooden post with steel wire threaded through acting as the guard rail. I have put YES/NO parameters for both the post and the wires in the POST family. I am free to turn these off and on when I am in the MODULE family, however in my project, I have no access to this parameter. Should I have not built the post in a second family and built the module all in the same family? I have set another YES/NO parameter in the MODULE family for the entire POST family (wires + post) so I can turn them off and on, but if I would like to turn only the wires off, while keeping the post, I can't. I feel the only way to do it without building it all together is to setup different family types for each situation, but it would be much easier if I could access each part seperately. I have attached the 2 families. Please advise. Thanks, ac
Is it that I used type parameters and not shared parameters? ac
In your H E L P , check out "nested parameters".
"nested parameters" doesn't seem to be a category in either the index or search. I did find "nested family" and "shared family" I've gotton it so I can tab select the subcomponent while in the project (by checking shared in the "family categories and parameters for the family--However, I can't change any of the parameters (they are all greyed out)
Where are you looking? see screenshot!
Also check out this great tutorial from Mr Spot that walks you through this process ... and the tutorial was right here in the tutorals area: http://www.revitcity.com/tutorials/arrays_and_nested/
Can you use type catalogs when the type is an embedded file? |
Thu, Mar 5, 2009 at 1:46:10 PM
Is it a good practic to embedde text label inside REVIT family? |
Thu, Feb 13, 2014 at 9:16:34 AM
Scheduling Detail families |
Tue, May 8, 2012 at 6:39:16 AM
embedded detail |
Wed, Jan 25, 2012 at 3:29:36 PM
Project Shared Parameters or Shared Parameters in Families |
Fri, Feb 21, 2014 at 10:22:43 AM
Members: | 2100424 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
