52 Users Online (50 Members):
Forums >> Workflow & Implementation >> Training >> Massing with regards to complexity
I have been playing around with Revit 2009 for the last year or so and have figured a lot out on my own, but I am having problems regarding the creation of masses and sub-masses. As all of my work is still at student level, it is 90% conceptual based. So I really like to push the boundaries and make more and more complex details within Masses. I generally use masses for the entirety of my project, then take it into 3ds Max 2009 to apply materials and render. The problem I face is that when I start creating masses (Both solid and void), the more I create the slower the system runs - which is expected. However, I was wondering if there is a way to alleviate or somehow slow down the slowing down as it were. I don't group my work, however I do use mirroing and copying. Is there a way to instance a copy in Revit like there is in 3ds Max 2009 (Shift + Drag click)? As I hear instancing is both easily editable and less of a memory hog. Any help would be thoroughly appreciated. Thanks, Sol
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
If your entire project 100% massing why don't you just do it in Max? As far as copying you can copyclip and paste or copy/multiple.
The idea was to learn both programmes as much as possible, and ultimately, I would like to be able to have the option to apply materials in either Revit (via wall creation etc) or 3ds Max.
That makes perfect sense. Well since your a student I would look at the Autodesk site to reap the benefits of your education, I am pretty sure you can get a student version of Revit 2010 and Max 2010 pretty easily. The massing abilities in 2010 are infinitely better than 2009 with the addition of the conceptual massing tool.
Yeah we get a 400 day license with our student email - it's awesome! Ok thanks, I'll check them out.
why my massing can't not be a solid? |
Fri, Feb 11, 2011 at 8:26:42 PM
Massing |
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape |
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model |
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP! |
Fri, Nov 6, 2009 at 4:07:53 PM
Members: | 2022542 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
