127 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Loading Families
Mon, Apr 20, 2009 at 3:26:22 PM | Loading Families
Aldigator
OK, I'll admit it, I'm really new to revit.  I work for a GC and am trying to use modeling to gather information (quantities, etc), and I'm also trying to do some design so I know how the project works, but I'm having a rough time of it.
Here's my question. I've been trying to model really small projects.  The last thing I was trying was a small shed and I wanted to show all the studs so I tried loading the Dimension lumber family and I think I did, but have no clue how to get a 2X4 stud for example.  Where am I going wrong?
Mon, Apr 20, 2009 at 4:17:23 PM | Loading Families
2x4 studs are detail families.  You can use them under the drafting tab - "detail component" - then the choice will appear on your options bar.
NOTE:  These are 2D elements.  Revit does not model studs in walls.
Tue, Apr 21, 2009 at 4:24:26 PM | Loading Families
Aldigator
I thought the elements I was bringing in were 3d.  This is what I have done.  I have put in some vertical studs and attached a 1" thick "wall" to the edge.  Can't I model like this?  Also, is there a way to have the lines on plan show thinner?  When I put a 1" thick wall in plan it looks like a big blob.  See attached.
Tue, Apr 21, 2009 at 4:36:44 PM | Loading Families
Revit uses a hevy line on each face of a wall.  If you put a 1" wall on the face of the studs, each side of the 1" will be heavy.  Instead, build your whole wall as one and place your stud families inside the cavity for the studs if you want to....
but I have to ask - why?  Why model the studs?  If you are doing 3D framing and turn off the walls, that's a different story - but wow - why?
Tue, Apr 21, 2009 at 4:41:24 PM | Loading Families
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
I'm more than inclined to agree with WWHub.  Unless you specifically need to show the studs, don't.
Loading Families
Mon, Nov 23, 2015 at 7:25:45 AM
Loading families
Thu, Apr 25, 2013 at 11:23:05 AM
Issues with loading downloaded families
Thu, Jan 9, 2014 at 12:11:36 PM
Revit Architecture 2015 - Families not loading
Mon, May 25, 2015 at 10:44:08 AM
Fri, Feb 1, 2013 at 11:15:08 AM
Page generation time: 1.2595
