85 Users Online (83 Members):
Forums >> Revit Systems >> Technical Support >> 3D Section
10 Posts No Rating |
Hi! How can I make a 3D section of my project?
What???? did you see in the help Menu??? Section box??? Crop Region??? Far Clip???? I don't know, something like this....
Edited on: Mon, Apr 20, 2009 at 9:48:17 AM
Sorry.... I'm italian. I want to create a 3D section.
i don't know.... i wont to make a section of my project thaht cut the first level in a place, the secondo in an other.... etc.... in italian is an "split"
Sorry - I don't believe you can do what you want. Look in your help at orient to view....
Edited on: Mon, Apr 20, 2009 at 9:57:54 AM
Ok thanks
Edited on: Mon, Apr 20, 2009 at 9:57:20 AM
2 Posts No Rating |
Creating a 3D Section in Revit
Have a model created from which you can create a section and 3D view perspective. - Using the default 3D view that is in the project browser create a duplicate of this view. Select the view then use the secondary mouse button to “Duplicate”
- Select the new Copy of the view created and using the secondary mouse button rename the view.(ex: 3D Axonometric View)
- Go to a plan view to create a new Section for a particular part of the model. (ie: Building Section, Wall section)
- Rename the section (ie: Axonometric Section) in the same manner that the 3D view was renamed.
- Make the 3D Axonometric view in the project browser active by double clicking the name in the project browser.
- Go to the View pull down menu and select “Orient” → ”To Other View” tool.
- Select the name of the section that was just created from the “Orient to Other View” dialogue box.
- The new active view will look just like the section view that was created before; the biggest difference will be when you select the “Dynamically Modify View tool” and select the Shift Key and hold down the scroll wheel on your mouse.
- This will activate the rotate command and now you will see the section created from an axonometric view perspective.
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
Section Head with Typical |
Tue, Jan 29, 2019 at 8:18:27 PM
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
The option to create Wall section not showing up, only building section. |
Wed, Jan 23, 2013 at 3:16:46 PM
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
