52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dwg in revit
Sun, Apr 19, 2009 at 11:35:09 AM | dwg in revit
12341234ddd
hi,
i imported a DWG file and the font of the file is other font.
how i change the font of the DWG file in Revit? i need to see the text beacuse i make architectural visualization of a house.
thanks, roei.
Sun, Apr 19, 2009 at 1:44:55 PM | dwg in revit
4 Stars: 201 Votes
So, after you explode the dwg pick in one font, then with the right button of mouse, "Select all instances" then go to the properties and change the font you want like you can see in the image attached...
Sun, Apr 19, 2009 at 11:36:39 PM | dwg in revit
12341234ddd
thanks.
but my dwg file has 19480 elements and Imports with more than 10,000 elements cannot be exploded.
how i explode only the text in the dwg file?
thanks.
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Revit to DWG
Fri, Jan 14, 2011 at 11:56:25 AM
Solution 2D DWG to REVIT Pls
Sun, Jun 18, 2006 at 6:04:13 AM
DWG and revit preformance
Mon, May 15, 2017 at 2:24:05 AM
Revit to DWG in one single flie.
Mon, Sep 22, 2014 at 4:01:47 PM
Page generation time: 1.8342
