119 Users Online (118 Members):
Forums >> Revit Building >> Technical Support >> How to create Roof Sheeting profile 28 metres wide
7 Posts No Rating |
Hello, I am trying to create a 28m wide profile of custom orb roof sheeting using a standard profile i dowloaded from steel select. I have spent 2 hours meticously copy the standard profile along the reference plane using reference lines and then trimmimg the overlapped lines. But when i load this profile into the project and try to use it as a fascia host sweep it cant be used. The standard profile works but is 27 metres too short so there is an error with the profile i have created but i dont know how to search for this error. can anyone suggest how i can overcome this problem?? Thanks
Can you put some images of what are you trying to do???
7 Posts No Rating |
Thanks, I was able to create the roof profile for a length of 5.5 metres but beyond that it was too much for my old system with only 1GB of Ram. The roof sheet profile was reasonably complex and curved so instead i've just applied a material.
Roof Sheeting Overhang |
Thu, Sep 15, 2005 at 10:59:45 PM
Corrugated Iron Sheeting |
Fri, Nov 30, 2007 at 5:04:09 PM
Metal deck roof profile |
Fri, May 13, 2011 at 1:05:51 PM
please help with ibr roof |
Sun, Jun 14, 2015 at 8:12:50 PM
Roof by footprint won't work in view |
Fri, Jul 9, 2010 at 12:10:55 AM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
