46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> how to connect monolithic stair to f.c. slab
![architurk Avatar](user_avatar/24361.jpg)
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Hi everybody Does anybody know a way to connect a f.c. slab (with some layering on it for example) to the lower part of a f.c. (monolithic) stair? On the upper part of the stair there is no problem, "end with riser" optio uncheck stair finishes and slab starts almost perfectly. (Not perfect, because I cannot "join geometry" and diminish the line between the slab and stair.) (PIC-1) But at the lower part of stair, "start with riser" option comes up with two almost the same results. When i extend the last riser line, Revit just extends the "tread" not the construction underneath (PIC-2 left side) I want my concrete stair to sit on and connect perfectly to my concrete slab on lower part. I wanna achieve sth like that in PIC-3.
Edited on: Fri, Apr 17, 2009 at 2:40:27 PM
monolithic stair join at floor slab |
Wed, Sep 24, 2014 at 11:30:35 AM
CAN'T MAKE MONOLITHIC STAIR |
Fri, Feb 5, 2016 at 10:16:18 AM
13
monolithic stairs |
Sun, May 16, 2010 at 6:33:12 AM
Creating concrete stairs from raised exterior slab |
Sat, Oct 25, 2014 at 10:26:43 PM
Monolithic Stair with Stringer |
Wed, Aug 5, 2009 at 10:43:24 AM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
