Forums >> Revit Building >> Technical Support >> Sub Discipline under Views?
I need help, I had created couple Sub folders of Discipline But now i need to create couple more i cant. I right click on the floor plan and properties and under Discipline wont let me add any, only let me select from a list. I attached a picture tp should were i am when i do this. Am i missing something? or is there a place to create a new Discipline for the list. Help, i have to get this fixed today. James
I think you may be asking a different question than what you have asked. Do you really want disciplines or do you want to organize your browser?
I want disciplines, there is Architectural, Electrical, Mechanical and Structural. But i need to add Fire & Safety, Landscape under the Views. My Sheets are ok. I already have my browser filtered to the disciplines. Its i cant add the others(Landscape, Fire, etc.) to it. I want to keep the Views for each seperate, so im not having to scroll through so many.
You can not add disciplines... but if you look at what I posted, you can add sub items to your views so that you can sort them... If you want the answer on that - look in the forums using browser as your search. Have a good weekend.
Controlling Display setting per Discipline |
Fri, Feb 17, 2012 at 12:33:05 PM
Can't find Sub-Discipline in Properties |
Mon, Jan 27, 2014 at 5:24:23 AM
How to change the name of discpline and sub discipline in revit project browser? |
Tue, Jul 7, 2009 at 4:02:40 AM
2013 revit new sheets not opening in correct discipline |
Tue, Mar 18, 2014 at 8:55:37 AM
Masking Regions and Discipline |
Wed, Oct 24, 2012 at 1:24:19 PM
Members: | 2104008 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
