52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> WORKSETS
Fri, Apr 17, 2009 at 9:13:28 AM | WORKSETS
koolair
4.5 Stars: 2 Votes
Hello fellow reviteers!
After four months of developing my mechanical systems using the local/central file approach, the topic of using worksets has been raised amongst my team of consultants.  I never knew about this!  Sounds interesting.
Could someone tell me how I can move my elements and stuff in my local model into a workset?  I R-click on a VAV box (for instance) and scroll down, next to WORKSETS it's set to the default "shared levels and grids".  But the words are greyed out so that I can't move it to another workset.  Hope someone can help!
BTW, anyone have any links to a site that details all the whys and hows of using worksets?
Thanks in advance
Joe
Fri, Apr 17, 2009 at 9:59:57 AM | WORKSETS
A good place to start in understanding worksets is just to use your H E L P !  Creating, adding elements to worksets, best practices ... iti's all there.
I really don't understand what's so hard about the concept of using the HELP.
Fri, Apr 17, 2009 at 10:37:23 AM | WORKSETS
Ash1012
First you have to make the worksets you want. Click ok and save to central.
Then go back in to the worksets thing and switch the editable column to no for the worksets (it wont let you do this unless you saved to central first).
The grayed out issue you're having. I'm willing to bet one whole dollar that when you select the item, you're seeing a light blue puzzle piece pop up next to it. Click that puzzle piece to make it "editable" and then try to change the workset in the properties.
I had the same exact issue.
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:13 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:19 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:16 PM
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:41 AM
Tue, Oct 23, 2007 at 2:36:14 PM
Page generation time: 0.9323
