64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Transparent Floor Plan when printing to PDF?
Fri, Apr 17, 2009 at 12:04:27 AM | Transparent Floor Plan when printing to PDF?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
I am trying to plot my floor plans in PDF so that when I throw them in Photoshop, they are transparent. So that only the lines of my plan are visible. At the moment, when I go to plot, there is a white background around the lines. What I am trying to do is put layers of color in Photoshop under the floor plan. Is this even possible? In the past I've had drawings that were transparent... I dont know if it depends on the view? Or if there is a printing setting? I did a search and nothing popped up.
Fri, Apr 17, 2009 at 12:23:08 AM | Transparent Floor Plan when printing to PDF?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Open the PDF in photoshop, select colour range and select all the white, then delete it...   You should be then just left with the linework...
Regards,
Chris.
Fri, Apr 17, 2009 at 1:06:25 AM | Transparent Floor Plan when printing to PDF?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
yea that is what Ive been doing... problem is that it leaves a slight trace of white behind, and it isnt as sharp or clean when its originally printed as a PDF
Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, May 8, 2012 at 2:49:41 PM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
17
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
cant print floor plan to PDF
Mon, Sep 17, 2012 at 8:30:08 AM
Need help with visibility/printing settings
Thu, Nov 26, 2015 at 5:23:53 PM
Page generation time: 2.1726
