66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Placing Door in Design Option Error
Thu, Apr 16, 2009 at 12:52:11 PM | Placing Door in Design Option Error
zabel
I'm in Revit Bldg 09.
Working in a design option, I try to insert a door into an existing wall and get this error:
"An insert in a design option cannot be hosted by an element in the Main Model."
I am BLOWN AWAY by this limitation!  Almost speechless.  What an oversight!
I thought I could "work-around" this by putting a new wall in place of the existing, but the new wall overlaps the existing and puts up the same error.
Anyone else have this issue, or better yet, a work-around that works?
Thu, Apr 16, 2009 at 12:54:59 PM | Placing Door in Design Option Error
You need a wall in each option - one will host the door.  Don't have the wall in the base.
Edited on: Thu, Apr 16, 2009 at 12:55:37 PM
Thu, Apr 16, 2009 at 3:24:45 PM | Placing Door in Design Option Error
tim123
4 Stars: 19 Votes
It's not a limitation - if you put a door in a wall you're changing it.  Simply click on the wall and 'Add to design option set (under tools).
Sun, Jun 23, 2013 at 6:52:41 AM | Placing Door in Design Option Error
capu57
I agree with the first 2.  I am redesign a house and want to show a few options one of which would be the door location.  The door will go into an existing wall and I should not have to copy the wall to every design option.  Same thing goes with lighting I had to delete my ceiling from the main plan in put ceiling in each design option.  Furthermore I should be able to demo a wall in a design option and do whatever I want.  I would understand if this only happened with NEW construction.  But I want to put a doors, lights, and windows into EXISTING walls and ceilings
I know adding a main model object to a design option is not hard but it should be unnecessary and design options should only contain NEW construction.  I should be able to create the existing bldg as the main model then using design options do all the demo and new construction I want.
Edited on: Sun, Jun 23, 2013 at 7:06:08 AM
Design Option Error
Wed, Mar 19, 2014 at 12:28:03 PM
Accepting Primary Design Option Causes Fatal Error
Tue, Dec 29, 2015 at 3:58:30 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Inserting Doors in Options
Wed, Sep 16, 2009 at 8:11:20 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Page generation time: 1.0395
