58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door cutting through two materials
Thu, Apr 16, 2009 at 11:23:41 AM | Door cutting through two materials
Rhudson
Revit Architecture 2009:
I'm wondering if it is possible to have a door cut through two materials. Here is the senario: I have a CMU wall (corridor bearing wall, stair shaft, etc.) that runs form the first floor all the way up to the top of the buliding... but in some cases an interior finish is needed and in some it is not. So I have decided to just use a plain cmu wall and I created a wall that is just the finish (stud and gyp) and atttach it where an interior finish is needed. It reads well in plan but when you cut a section/ elevation the where a door is it only has the finish on the sides not over the door (which makes sense).  So again all I need to know is if I can cut through the 2 walls with one door?
Thu, Apr 16, 2009 at 11:30:52 AM | Door cutting through two materials
jmbitzer81
I've had similar situations. The only ways I have been able to get that to work was to either make it a new wall type, a stacked wall, or fool the program and make the mtl stud and gyp bd. sweeps on your CMU wall.  I have not found a way to make any opening (door or window) cut through 2 walls.
Thu, Apr 16, 2009 at 12:04:51 PM | Door cutting through two materials
tim123
4 Stars: 19 Votes
Use the join geometry tool to combine the walls.  The door will cut through both.
Thu, Apr 16, 2009 at 12:55:25 PM | Door cutting through two materials
Rhudson
the join geometery worked great! Thanks for the responses.
door opening cutting parallel wall
Mon, Sep 15, 2008 at 2:54:11 PM
Door not cutting joined wall
Wed, Feb 14, 2018 at 12:54:55 PM
Wall sweep not cutting right with a door
Sat, Nov 3, 2007 at 12:43:11 AM
Add the Actual Door Materials to the Schedule
Fri, Jan 6, 2017 at 1:35:09 PM
Cutting of Overhead Doors
Sun, Jun 16, 2013 at 11:45:19 AM
Page generation time: 1.7956
