71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Area types
Thu, Jul 7, 2005 at 6:04:18 PM | Area types
BLIESNER
does anyone know if there is a way to create or edit different area types within the area schemes i want to change the common area to circulation space for my common hallways etc. thanks.
Thu, Jul 7, 2005 at 6:20:58 PM | RE: Area types
TomDorner
4.5 Stars: 25 Votes
The area types built into Revit are the standard BOMA types and cannot be modified. You can however create a new shared parameter for your own area type. You can also define a schedule key for your new area type and do calculations for occupancy, toilets, exits etc. HTH Tom
Area Plans
Wed, Nov 1, 2006 at 10:03:13 AM
Change unit types for property area tag
Tue, Jun 2, 2009 at 4:49:53 PM
Area Type - failed attempts to add
Wed, Sep 2, 2009 at 7:31:35 AM
Custum Area Type
Fri, Jan 6, 2006 at 11:57:27 AM
Area Plan Color Scheme Cannot be changed???
Thu, Sep 11, 2014 at 11:58:38 AM
Page generation time: 0.6018
