70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> please help- tried everything to get objects to accept material...
Tue, Apr 14, 2009 at 9:45:44 PM | please help- tried everything to get objects to accept material...
jukeboxangel
hi,
i can't seem to get some imported objects to accept a material. for example, when i import a few different dwg objects from the Kohler website it seems that only a few objects will take on a material. i've went into "oject styles/imported object" and changed the material in there but some objects just don't take on a material. even with some small uncomplicated objects i can't get them to accept a material.
i just need these objects to render a material!
thanks everyone for your valuable information and for your time.
Tue, Apr 14, 2009 at 10:55:56 PM | please help- tried everything to get objects to accept material...
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jukeboxangel, have you tried here:  Settings-->Materials....    A recommendation is to change the names of the materials by other i.e. "Render Material 0,0,0" to "Toilet color"...
Thu, Apr 16, 2009 at 12:45:05 AM | please help- tried everything to get objects to accept material...
jukeboxangel
i got it to work. the funny thing is that when i looked at the numerical color assigned to the object and changed the material it still didn't change.what i had to do was look at the graphic color assigned to the object which was light blue. then,i changed the material according to the matching color. the number that was light blue wasn't the number that was assigned to it in the object materials parameter however. strange?
thank you so much for your help though because it started me out in the right direction.
Is it possible to change the material on objects downloaded from revit city?
Thu, Feb 22, 2007 at 2:00:02 PM
adding material to a dxf object
Wed, Nov 9, 2005 at 11:13:35 PM
Copy and paste, and accept suggested location for items [ 1 2 ]
Tue, Jan 12, 2021 at 4:35:35 AM
21
Will not render objects completely??
Sun, Jun 28, 2009 at 9:21:33 AM
Placing materials on objects in a family
Mon, Dec 17, 2012 at 12:30:35 PM
14
Page generation time: 0.5866
