32 Users Online (31 Members):
Forums >> Revit Building >> Technical Support >> Visibility
I have a problem where I need some mechanical equipment to show up in the plumbing, but not HVAC, and some in HVAC but not plumbing. Example being a small pump on the recirc line that needs to show up on plumbing. I have two other pumps on the in floor heating lines that I need to show up on HVAC. If I set the visibility to either plumbing or HVAC, then the pump/pumps don't show up the other plan. If I leave them visible in both plans, then there is a pump/pumps that appear to be in the middle of nowhere. The only way I can think of to get around this would be to save the recirc pump to a different folder in the plumbing folder, and re-insert it as a piece of plumbing equipment. Is there a better way?
Turn them on then hide the ones you don't want.
Sorry, when you say "hide" them, how do I do that, is it similar to cad where you freeze or turn items off?
If you are on 2008 or later, just pick them, right click, then choose "hide in view" - elements.
Visibility Problem - please help!!! |
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility |
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY |
Mon, Aug 7, 2006 at 5:36:38 PM
Symbolic Element Visibility |
Tue, Feb 4, 2020 at 6:42:28 AM
Controlling window visibility |
Tue, May 12, 2009 at 12:49:39 AM
Members: | 2019203 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
